Warning message
Default interception behavior of TCP service 61 and 62?
Answered Question
Sep 28th, 2010
When using TCP service groups 61 and 62 in WAAS WCCP redirection, is the default behavior to redirect all traffic or only all TCP traffic? I'm using Cat6500 to do L2 redirection and considering using redirect-list to reduce WAE processing load. If all traffic is to be redirected, then I need to exclude VoIP media traffic (UDP) as well. If just TCP is to be redirected, then I don't need to deny UDP in the redirect-list.
Another question: is it possible to use "ip wccp redirect" for trunk ports in L2 redirection if the switch is Layer 2 only?
Thanks a lot
Correct Answer by ahskhan about 6 years 10 months ago
WCCP 61/62 are TCP-promiscuous, this means that All TCP ports will be redirected to WAE. UDP traffic will not be redirected, however please check with your VOIP solution and make sure that phone registration is not on TCP port, if it do then a WCCP flap will cause all phones to re-register in your network.
WCCP can only be enable on IPV4 / Layer 3 enable interface, so a Trunk port with dot1q truning with no ip on it will not redirect any packets.
Hope this helps.
Ahsan
Overall Rating: 5 (1 ratings)
Correct Answer
ahskhan Tue, 09/28/2010 - 18:17
  • Cisco Employee,
Hope this helps.
Ahsan
