7915 sidecar and 7962
Sep 28th, 2010
I have tried to get the 7915 sidecar to work on a 7962 phone with no luck. I am running CUCM 7.1.3 and I upgraded the 7915 firmware to B016-1-0-3 and the phone is running SCCP42.8-5-2SR1S. On another issue I can't get the phone to upgrade to SCCP42.8-5-3S over the WAN but shouldn't the sidecar work with  8-5-2SR1S? I do have some phones at HQ using 8-5-3S on 7962 that upgraded no problem and plan to deploy after a week of running with no issues on my test phones. Am  I facing a bug with the sidecar firmware?
Thanks.
dksingh Wed, 10/06/2010 - 10:18
  • Cisco Employee,
7962+7915 is supported. FW version on both seems compatible but its possible there
is an issue we may be hitting here...
When you say 7915 does not work, can you advise what exactly happens?
Things to check:
- Does 7962 upgrade fine if u remove 7915 altogether ?
- Enough buttons defined in phone-button-template being used depending on a 7915-12 or 7915-24 ?
- Using CP-PWR-CUBE-3 for 7915 ?
DK
