NAC Collector License message [FlexLM mismatch 1 verified]
Sep 28th, 2010
I have uploaded the license file in nac profiler, the server status is running but the collector is not in the running state it shows the following message.
Is this the collector licence issue or something else?
Also the collector version configured in profiler is 3.1.1-18. The version of collector in CAS is 3.1.0-24?. for both it should be same for communication?
Also if it is the issue of Collector License then how to get the evaluation license and for collector version upgrade it says to download the following •nac-collector-3.1.1-18-K9.rpm file. How to get it downloaded from cisco site.
Kindly help on this plz
Screenshot is attached for refrence.
Thnks,
Abuzar
Faisal Sehbai Wed, 09/29/2010 - 07:05
  • Gold, 750 points or more
Abuzar,
Versions have to match!
For licenses, the collector license should be issued to the Profiler's eth0's MAC address. If it's not, it's the wrong license then.
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
