I am not able to ping to other network which it connect etherswitch module
Sep 29th, 2010
   From Router 3925 which it has SM-ES3G-16-P etherswitch module from that module we have connect three more router in which is in different locations. I configured switch module and other end router i am able to ping each other. But i am able to ping from 3925 router if login into switch module i am able to ping. etherswitch has c3560-e-unviresal-mz-22.2(52) IOS. Whe i check eith some document that i need to configure vlan 1 ip add as same subnet of gigabit interface of switch module .Even though its not pinging. i need a help in this.
thanks in advance.
Ashley Georgeson Wed, 09/29/2010 - 00:33
Have you tried using the no switchport command and then applying an IP address to the etherswitch port that connects to another router?
This would make it a routed port, which may be what you need.
Regards, Ash.
chandru.j Wed, 09/29/2010 - 06:11
   Yes i given after that switched will be routed port then i am able give ip address to that port.
Wilson Gabriel ... Thu, 12/05/2013 - 12:02
Hello Chandru.j
Could you help me with the steps to configure and  SM-ES3G-16-P Module ? I am really new and I have to configure that card to conect  3 routers.
