09-29-2010 01:24 AM - edited 03-04-2019 09:56 AM
I have to terminate an E1 using VWIC2-1MFT-G703 Interface card on 2911/k9 router but as per my knowledge installing HWIC card in EHWIC slot requires an intermediate jacket but I am not sure. I shall be grateful if someone can guide me a) is it is possible b) how?
Solved! Go to Solution.
09-29-2010 04:22 AM
Nothing is needed to install this card.
Note, unless you must using unframed mode, the expensive -G703 version is not necessary.
09-29-2010 04:25 AM
Hello!
A. Yes. EHWIC's are of the exact same form factor as an HWIC. Hence any supported HWIC, WIC, VIC or VWIC will seat in an EHIC without the use of an adapter card.
https://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
In the PDF above you can see your card being supported by ISR G2 routers.
I hope this helps you!
Cheers,
Calin
09-29-2010 04:22 AM
09-29-2010 04:59 AM
Thanks Paolo for your quick response and support.
Arshi
09-29-2010 05:04 AM
You are welcome, thanks for the nice rating and good luck!
09-29-2010 04:25 AM
Hello!
Cheers,
Calin
09-29-2010 04:58 AM
Ddear Calin,
Thanks for your support, I have seen this document this morning but was not sure.
Arshi
09-29-2010 05:21 AM
Thanks for rating, really appreciate it!
Good luck and I hope to see you on this board again!
Calin
