How to get back to initial CUCM 7.x/8.x
Answered Question
Sep 29th, 2010
Hi, experts
After configuring CUCM7.x/8.x, I want to quickly remove all configurations for getting back to initial status. Could you let me know if there is a way to delete some files in the system by administrator or root account? Thanks for any help.
Correct Answer by Aaron Harrison about 6 years 4 weeks ago
No problem.
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
Overall Rating: 5 (1 ratings)
Aaron Harrison Wed, 09/29/2010 - 02:01
The only 'quick' way to a blank system would be to restore a backup taken when you first built the CCM from media and before configuring anything.
Once you have made configs; you can manually delete things via the GUI, or rebuild from media.
Even with root access you can't just go in and delete things - for example, 90% of what CCM is about is in the DB, you can't just delete the DB, you need the contents of it from the default build.
Please rate helpful posts..
