09-29-2010 01:57 AM
When a real server is in PROBE-FAILED status, I observe a syslog message at each trial of the proble. This fills our syslog server. Is there a mean to configure the ACE in such a way that a syslog message would be generated only when a transition occurs in the probe status ?
Thank you for any hints,
Yves
Solved! Go to Solution.
09-29-2010 05:37 AM
You can utilize "logging trap
"logging message
in order to achive what you are seeking.
The "logging trap
If it is set to "5 - notification", all messages that have security level of 5 or lower number are sent to the syslog server.
You can disable the display of a specific syslog
message or change the severity level of a specific system log message using
"logging message
Not sure what kind of probe you are using but If it is ICMP probe and
the reason of probe failure is arp, it generates a message for every try
as below with severity level of 3, by default.
%ACE-3-251009: ICMP health probe failed for server 192.168.0.1, connectivity error: ARP not resolved for destination ip address
%ACE-5-441002: Serverfarm (SF) is now back in service in policy_map (fs) -->
class_map (#class_default_slb). Number of failovers = 0, number of times back in service = 0
%ACE-4-442007: VIP in class: 'VIP' changed state from OUTOFSERVICE to INSERVICE
%ACE-4-442004: Health probe ICMP detected rserver r1 (interface vlan31) changed state to UP
%ACE-4-442001: Health probe ICMP detected r1 (interface vlan31) in serverfarm SF changed state to UP
If your "logging trap
the message "%ACE-3-251009:xxx" to be sent to syslog server,
you can change its security level like below.
switch/Admin(config)# logging message 251009 level 6
switch/Admin(config)# do show logging message 251009
Message logging:
message 251009: current-level 6 default-level 3 (enabled)
You can check the message id that is filling the syslog server
and change its security level to higher number than "logging trap
Kimihito.
09-29-2010 05:37 AM
"logging message
The "logging trap
"logging message
Message logging:
Kimihito.
09-29-2010 06:14 AM
Hi Kimihito.
Thank you for your answer, it is exactly what I was looking for.
best regards,
Yves
