CAS server installation question
Sep 29th, 2010
Iam preparing to install L2 VG NAC soution and through my study in the user guide of the CAM and CAS i found the following caution :
" To avoid switch errors and switch shudown, make sure to correctly set VLAN Mapping in the CAS before connecting the eth1 interface of the CAS "
i need to know what will be the issue when connecting the two interfaces of the CAS before setting VLAN Mapping???
waiting your replies
MAM
Faisal Sehbai Wed, 09/29/2010 - 07:08
  • Gold, 750 points or more
Mohammed,
If you don't set it right, there's a chance of a broadcast storm taking out your switches!
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
