show ip slb stats?
Sep 29th, 2010
What does all this mean? I'm particularly in the entries which indicates errors:
I looks like a serious problem, with over 100.000 failed connections, in only 700.000 created connections.
Connections Created:        692177
Connections Destroyed:      591523
Connections Current:        100654
Connections Timed-Out:      21192
Connections Failed:         115898
Server initiated Connections:
      Created: 0, Current: 0, Failed: 0
L4 Load-Balanced Decisions: 693066
L4 Rejected Connections:    0
L7 Load-Balanced Decisions: 0
L7 Rejected Connections:
      Total: 0, Parser: 0,
      Reached max parse len: 0, Cookie out of mem: 0,
      Cfg version mismatch: 0, Bad SSL2 format: 0
L4/L7 Rejected Connections:
      No policy: 0, No policy match 0,
      No real: 0, ACL denied 0,
     Server initiated: 0
Checksum Failures:  IP: 0, TCP: 0
Redirect Connections: 0,  Redirect Dropped: 0
FTP/RTSP Connections:            0
MAC Frames:
      Tx: Unicast: 78312749, Multicast: 1455988, Broadcast: 1240,
          Underflow Errors: 0
      Rx: Unicast: 78272614, Multicast: 3911, Broadcast: 1237,
          Overflow Errors: 900, CRC Errors: 0
Best Regards
Henrik Stryhn, Denmark
jny Thu, 09/30/2010 - 13:40
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
“The number of TCP and UDP connections destroyed by SLB, either by TCPIP teardown or timeout. UDP connections can only be timed out."
                      “UDP connections destroyed as result of timeout”
/nykaer
