Gig1/0 shuts itself
Sep 29th, 2010
Hello team,
is  there any particular reason why the management interface Gig1/0 (set as primary int) can shut  itself? It is configured to autosense. WAE type is WAE-674-K9 with  oe674-4.1.5f.2 IOS version. I tried to change the speed and duplex settings but when I type "no shut" it still remains in admin down status.
Many thanks!
Stan
Bhavin Yadav Wed, 09/29/2010 - 11:32
  • Cisco Employee,
Hi Stan,
Please make sure to follow-up the cabling guidelines mentioned here: Cabling
I know above link is for inline adapter but it remains true for gig 1/0 while using WCCP, too..
You may want to try same thing on gig 2/0. If the same issue continues with gig 2/0, it may be the cabling or the interface issue on router / switch where it is connected.
Can you paste the sh int g 1/0 interface output here while it is workign and not working ?
What is the status of interface (on switch / router) connected to WAAS gig 1/0 when it shows down?
If the issue continues, you may want to open up a TAC case as this may be the hardware issue on interface itself.
