Setting up RTLS with Cisco
Sep 29th, 2010
We are looking to create asset tracking solution in office based on CISCO unified wireless product.The following CISCO device are available in office.
- CISCO Wireless Controller (Model: 5508)
- CISCO 3300 Series Mobility Services engine
- CISCO Wireless Access Point(AIR-LAP1142N-C-K9)
I have connected the AP directly to the Wireless controller and the wireless controller is not able to detect the APs. Do i need a layer 3 switch so the controller can detect and communicate with the APs?
Elliott Shawd Sat, 10/02/2010 - 23:52
Yes. Unless you setup a DHCP server on your controller, the LAP will need to pull an address from somewhere before it is able to communicate.
myselfs23 Sun, 10/03/2010 - 04:43
Thanks, but the problem is even after configuring DHCP on the controller,, The controller still can't connect to the APs.
I'm getting an error message trying to connect to the AP through DOS CLI:
doesn't have enough power, I'm using a D-Link POE supplier to power up the AP,  cause the controller not to connect to the AP.
The other error we're getting is that CAPWAP, Not sending the request, AP does not have the IP.
Elliott Shawd Sun, 10/03/2010 - 12:06
I would grab an AC adaptor and power the AP locally.Then, I would find a layer 3 switch to plug your controller and AP into.
Surendra BG Fri, 10/08/2010 - 21:35
  • Cisco Employee,
if you have connected the APs directly to the WLC then whets does the output say..
"show CDP nei det" on the WLC?? >> Are the APs getting the IP address??
"show port summary" on the WLC?? >> are the ports up??
If the AP is not getting the IP address then it will not joing the WLC.. try assigning the static ip address and see what happens..
Surendra
Raul Manzano Barroso Mon, 10/18/2010 - 05:10
From AP console:
lwapp ap ip address
lwapp ap ip default-gategay
lwapp ap controller ip address
Consider two points:
- If the AP was registered in other WLC, you cannot set this parameters through console connection, if you do that you will see a "Error, Command is disabled" message.
- If you use software version 5.2 and later (in your AP), these commands may change from lwapp to capwap.
Best Regards.
