Deleting the client immediatly since WLAN is changed
Sep 29th, 2010
Hello;  I recently upgraded our 5508s to 7.0.98 I am now seeing this mesage on the primary WLC while running adebug on a client *apfMsConnTask_1: Sep 29 11:05:36.114: Deleting the client immediatly since WLAN is changed.  anyone know what this means?
George Stefanick Wed, 09/29/2010 - 14:05
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Im sure one of our Cisco friends can answer this ... I haven't seen this before specific to WLAN. Deleting client often means its deleting the client association. Is this client having issues by chance?
JOHN SAINATO Thu, 09/30/2010 - 09:47
Yes, several users throughout the day disconnect and then reconnect.
Stephen Rodriguez Fri, 10/01/2010 - 16:55
John,
     Take a look at the Controller tab.  One of the options there, is Fast SSID Change, set this to enable and see if this helps.
craig.eyre Wed, 09/14/2011 - 13:10
John,
Have you figured out a solution from your problem? Did the fast ssid change work?
In my scenario I disabled it as I would see clients connecting from one SSID to another but retaining their ip address from the 1st ssid.
This is bad (or I've missed something) if you have different firewall rule sets for these 2 SSID's.
Craig
pcroak Wed, 09/14/2011 - 14:47
  • Cisco Employee,
Hi Everyone,
This debug message is not properly filtered when running a client debug. It is printed whenever ANY client on the controller switches WLANs, not just the client we are debugging. Since clients out there sometimes like to bounce around when multiple profiles are configured, this message can often be ignored.
See CSCtr07846 for more details.
-Pat
Matheus Lopes Thu, 07/28/2016 - 08:33
I had exactly the same issue with clients who were trying to connect with their IPhones and i was getting the same error through the logs. Deleting the client immediatly since WLAN is changed.
The solution was enable FAST SSID change on the Controller.
There is an option in WLC to enable FAST SSID change. By default its disable.
When fast SSID changing is enabled, the controller allows clients to move between SSIDs. When the client sends a new association for a different SSID, the client entry in the controller connection table is cleared before the client is added to the new SSID. When fast SSID changing is disabled, the controller enforces a delay before clients are allowed to move to a new SSID.
Enable FAST SSID via GUI:
Login WLC GUI: Go to Controller to open the General page.
From the Fast SSID Change drop-down list, choose Enabled to enable this feature
Click Apply
Click Save Configuration on the right side on top.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
