DHCP server question on 1141N
Sep 29th, 2010
I currently have DCHP server set up on my new 1141N. Everything works great, but I wanted to know if it were possible to make the DHCP server only hand out ip addresses on the wireless connection? Currently the AP is giving out ip addresses from the pool to wired and wireless pc's. Thanks for your help.
Overall Rating: 5 (1 ratings)
b.garczynski Wed, 09/29/2010 - 09:21
Matt,
I would recommend using separate subnets between your wired and wireless networks. Then you should create a DHCP scope to only hand out addresses on the wireless subnet.
George Stefanick Wed, 09/29/2010 - 14:11
As b.gar point out you sure can . 5 point to you B.gar!
I would becareful because i dont think the AP binds the addresses after reboot? Someone... correct me if im wrong.. that may or may not be an issue for you ...
Vinay Sharma Sun, 09/25/2011 - 10:41
Hello Matt,
Please mark the Question as Answered, if the provided information by Brad and George is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
