Routing failed to locate next hop for icmp from NP Identity Ifc
Sep 29th, 2010
I'm getting a strange error when I try to ping a host on the remote end of  VPN from the DMZ..
Ping dmz 192.168.4.20
Show log asdm:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
6|Sep 28 2010 14:53:29|110003: Routing failed to locate next hop for icmp from NP Identity Ifc:10.10.8.1/0 to dmz:192.168.4.20/0
Is this a problem on the remote end, or something I can fix, attached is the config:
Marcin Latosiewicz Wed, 09/29/2010 - 09:05
  • Cisco Employee,
Gregory,
Are you should that address is available via dmz interface?
Can you please show me "show route"?
Marcin
