limiting bandwidth for respective tunnels on my cisco router.
Answered Question
Sep 29th, 2010
Hello expert,
I have a router(Spoke) that has two tunnels to my Hub.
I need to cap(limit)  the bandwidth on both tunnels example tunnel  A – 512 k and tunnel B 1.2M
I want this to be applied during normal transmission , hence I did not do QoS  since this
will only apply when there congestion on the line.
Can anyone advise how to set the above on the router using SDM or CLI .
Jomo
Correct Answer by John Blakley about 6 years 9 months ago
Are you using tunnel interfaces? You'll need to create a QoS policy and shape on the default class. If you're using tunnel interfaces, you *might* need to create 2 policy maps: one for each tunnel that you want to match on. (I've never done this, but seems plausible.) How are you routing traffic over these two tunnels? Are they used for certain types of traffic or certain destinations?
HTH,
John
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Wed, 09/29/2010 - 09:37
  • Purple, 4500 points or more
HTH,
John
