VIC2-4FXO - Caller ID works with CME, but not CCM7
Sep 29th, 2010
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
Have a VIC2-4FXO card installed in a Cisco 3725.  Caller ID works when the unit is in CME mode, but cannot get it to work with CallManager.
I'm scratching my head here, but can't figure out what I'm missing.
Any ideas?
Overall Rating: 3 (1 ratings)
paolo bevilacqua Wed, 09/29/2010 - 10:24
  • Hall of Fame,
    Founding Member
Are you using H.323 or MGCP with CM ?
Clifford McGlamry Wed, 09/29/2010 - 10:34
MGCP.  I guess I could convert it to H323, but that's annoying to have to do that.  It seems like this should work.
paolo bevilacqua Wed, 09/29/2010 - 10:38
  • Hall of Fame,
    Founding Member
MGCP, among other limitations, does not support CLID.
So, if you want CLID, you will have to convert.
Clifford McGlamry Fri, 10/01/2010 - 14:28
Interesting, but the documentation doesn't match what the interface actually has.  I set up an 8.0.2c box in the lab, and tried this out.
This is a VIC2-4FXO in a 3725 gateway.  There is no box to enable caller id in the port configuration as described in the document.
Sounds like some feature either got removed, or the documentation is incorrect.  It's not there.
paolo bevilacqua Sat, 10/02/2010 - 02:20
  • Hall of Fame,
    Founding Member
You have a solid, flexible and standard alternative in using H.323 or SIP.
Why you want to fight with MGCP instead ?
ssadayap Sun, 10/03/2010 - 12:45
  • Cisco Employee,
3725 is EOS. latest version of IOS in other routers (28xx,38xx) supports the FXO caller id feature for mgcp gw
Related Content
