Two 1242ag bridge with 5gz at 800'
Sep 29th, 2010
I need to bridge from our office to our shop that is around 800 feet away.  Here are the Details
I need the 2.4 ghz antenna for client access (Iphones are not compatiable with 802.11a)
The locations are 800 feet away but are line of sight.
I need to use the 5ghz antenna for the bridge
i have 2 aironet 1242ag's
I have 2 2.4 ghz AIR-ANT3213 antennas (planned for client access)
I have 2 2.4 ghz AIR-ANT2506 (maybe useless for this)
My problem is that the range of all the listed 5 ghz antennas.  None that i can find will bridge 54mb over the 5ghz radio for greater than 170ft
The closest that i can find is AIR-ANT5195.  If i put these on both sides and it is outdoors line of sight, will the best i can hope for is functioning and 6mb
are there any other antennas that would be a better fit? Are there options on 5ghz that i am missing.
George Stefanick Wed, 09/29/2010 - 14:00
Get yourself a pair of cheap tranzeo bridges. They are small light and do the trick. They are self contained units so no need for extra antennas etc ... I just hooked up a pair with Cisco APs on each end for end user connections. We are about 800 feet away as well, but we have LOS. I dont know what you have to puch through but i think not having LOS will be a bigger issue ..
Vinay Sharma Sun, 09/25/2011 - 10:43
Hello Kevin,
Please mark the Question as Answered, if the provided information by George is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
