ACS 5.1 AD configuration steps
Sep 29th, 2010
Finally the acs box has joined the domain now. What are the neccessary step required for authentication via the domain. eg, what do I need to do on the acs box so that domain users can be authenticated to log on to devices?
i have done the neccessary tacacs config on the host but they fail authentication.
Is there anything like group mapping or what?
In a summary, what are the configuration steps on the acs after joining it to the domain?
thanks all.
Javier Henderson Thu, 09/30/2010 - 08:59
You need to select AD to be the identity store for the applicable authentication policy. By default this will be the local store.
