Active-Active firewall and virtual MAC address
Answered Question
Sep 29th, 2010
Hi All,
i have Active - Active firewall and want to change the firewall virtual MAC address.!!!
is it possible ?? and if it is ,how can i do it??
Thanks in advance,
Ayman
Correct Answer by mirober2 about 6 years 8 months ago
Hi Ayman,
Yes, you can do this command for either failover group while you are in (config-fover-group)# mode.
Hope that helps.
-Mike
Hi Ayman,
Yes, you would do it within the failover group. Here is an example from the command reference:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/m.html#wp2026897
hostname(config)# failover group 2
hostname(config-fover-group)# secondary
hostname(config-fover-group)# preempt 100
hostname(config-fover-group)# mac address e1 0000.a000.a011 0000.a000.a012
hostname(config-fover-group)# exit
Hope that helps.
-Mike
Hi Ayman,
Yes, you can do this with the 'mac address' command. Here is the command reference;
Hope that helps.
-Mike
Overall Rating: 5 (3 ratings)
ayman emara Wed, 09/29/2010 - 11:33
HI mike,
the commands are in active- standby mode.
is it applied also in active - actvie mode.
thanks
Ayman
Correct Answer
mirober2 Wed, 09/29/2010 - 11:36
  • Cisco Employee,
Hi Ayman,
Hope that helps.
-Mike
ayman emara Wed, 09/29/2010 - 12:15
Hi mike,
this will change the secondary MAC address only.
can i do this commands for the primary group also.
Ayman yehia
Correct Answer
mirober2 Wed, 09/29/2010 - 12:42
  • Cisco Employee,
Hi Ayman,
Hope that helps.
-Mike
