GET VPN KS COOP Issue
Answered Question
Hi Group
I'm in the process of testing GETVPN on a developement network before I deploy.  I have a basic setup of 1 KS and 3 GM's  which is working fine.  The next stage of my testing is to deploy a second KS using COOP.  The configuration on both KS are indentical except for the priority and addresses etc. see below
KS1
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp key tempkey1 address 192.168.64.4
crypto isakmp key tempkey1 address 192.168.80.4
crypto isakmp key tempkey1 address 192.168.1.254
crypto isakmp key tempkey1 address 192.168.64.5
crypto isakmp keepalive 15 periodic
crypto ipsec transform-set aes128 esp-aes esp-sha-hmac
crypto ipsec profile profile1
set security-association lifetime seconds 7200
set transform-set aes128
crypto gdoi group GDOI-GROUP1
identity number 12345
server local
  rekey algorithm aes 128
  rekey retransmit 10 number 2
  rekey authentication mypubkey rsa getvpn-export-general
  rekey transport unicast
  registration interface Loopback80
  sa ipsec 1
   profile profile1
   match address ipv4 getvpn-acl
   replay time window-size 5
  address ipv4 192.168.1.255
  redundancy
   local priority 100
   peer address ipv4 192.168.2.255
KS2
encr aes
group 2
server local
  sa ipsec 1
   profile profile1
  redundancy
   local priority 250
   peer address ipv4 192.168.1.255
The crypto keys have been generated and exported on KS1 and import on KS2.  The KS's are 2821 routers running c2800nm-advsecurityk9-mz.150-1.M3.bin.
The following show crypto gdoi ks coop, shows that the KS coop operation is holding at registering
KS1#sh crypto gdoi ks coop
Crypto Gdoi Group Name :GDOI-GROUP1
        Group handle: 2147483650, Local Key Server handle: 2147483650
        Local Address: 192.168.1.255
        Local Priority: 100
        Local KS Role: Secondary , Local KS Status: Alive
        Secondary Timers:
                Sec Primary Periodic Time: 30
                Remaining Time: 0, Retries: 0
                Invalid ANN PST recvd: 0
                New GM Temporary Blocking Enforced?: No
                Antireplay Sequence Number: 0
        Peer Sessions:
        Session 1:
                Server handle: 2147483655
                Peer Address: 192.168.2.255
                Peer Priority: 0
                Peer KS Role: Secondary , Peer KS Status: Unknown
                IKE status: In Progress
                Counters:
                    Ann msgs sent: 0
                    Ann msgs sent with reply request: 0
                    Ann msgs recv: 0
                    Ann msgs recv with reply request: 0
                    Packet sent drops: 0
                    Packet Recv drops: 0
                    Total bytes sent: 0
                    Total bytes recv: 0
Debugs Cryptographic Subsystem:
  Crypto ISAKMP debugging is on
  Crypto IPSEC debugging is on
Sep 29 19:59:36.255: ISAKMP:(0): no idb in request
Sep 29 19:59:36.255: ISAKMP:(0): SA request profile is (NULL)
Sep 29 19:59:36.255: ISAKMP: Created a peer struct for 192.168.2.255, peer port 848
Sep 29 19:59:36.255: ISAKMP: New peer created peer = 0x46893648 peer_handle = 0x800004F8
Sep 29 19:59:36.255: ISAKMP: Locking peer struct 0x46893648, refcount 1 for isakmp_initiator
Sep 29 19:59:36.255: ISAKMP: local port 848, remote port 848
Sep 29 19:59:36.255: ISAKMP: set new node 0 to QM_IDLE
Sep 29 19:59:36.255: ISAKMP:(0):insert sa successfully sa = 47325510
Sep 29 19:59:36.255: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
Sep 29 19:59:36.255: ISAKMP:(0):No pre-shared key with 192.168.2.255!
Sep 29 19:59:36.255: ISAKMP:(0): No Cert or pre-shared address key.
Sep 29 19:59:36.255: ISAKMP:(0): construct_initial_message: Can not start Main mode
Sep 29 19:59:36.255: ISAKMP: Unlocking peer struct 0x46893648 for isadb_unlock_peer_delete_sa(), count 0
Sep 29 19:59:36.255: ISAKMP: Deleting peer node by peer_reap for 192.168.2.255: 46893648
Sep 29 19:59:36.255: ISAKMP:(0):purging SA., sa=47325510, delme=47325510
Sep 29 19:59:36.255: ISAKMP:(0):purging node 1257862736
Sep 29 19:59:36.255: ISAKMP:(0):cleaning up GDOI node 1257862736
Sep 29 19:59:36.255: ISAKMP: Error while processing SA request: Failed to initialize SA
Sep 29 19:59:36.255: ISAKMP: Error while processing KMI message 0, error 2.
Sep 29 19:59:36.255: IPSEC(key_engine): got a queue event with 1 KMI message(s
I see from the groups that there a lot of people using COOP with no issues like this have I missed something fundamental?
Correct Answer by Collin Clark about 6 years 10 months ago
You're missing an isakmp key for the COOP KS. They create a VPN connection to each other just the GM's do. I see that the KS IP's are 192.168.x.255. I assume that their real IP is not a broadcast address?
KS1 needs something like-
crypto isakmp key mYcOoPkEy address [key server 2]
and
KS2 needs something like-
crypto isakmp key mYcOoPkEy address [key server 1]
Hope it helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Collin Clark Wed, 09/29/2010 - 13:16
  • Purple, 4500 points or more
and
Hope it helps.
Collin Clark Wed, 09/29/2010 - 13:38
Glad to hear it's working. I worked off the the configuration guide v1.0 which is excellent (and at the time I deployed the only one available).
