Do I need to uninstall the current CSC-SSM Patch before installing the latest patch?
Sep 29th, 2010
We are currently on 6.1.1569.2 on our CSC-SSM on our ASA5520.  Installing the upgrade to through the GUI looks fairly straight forward.  Is there any reason I should do it CLI instead?  Also do I need to uninstall the 6.1.1569.2 path before installing the most current?  Could I uninstall it afterwards?  Do I need to uninstall it at all?
Thanks.
--Sandy
Allen P Chen Wed, 09/29/2010 - 13:35
  • Cisco Employee,
With regards to the upgrade *.pkg files, those can only be installed through the GUI of the CSC-SSM.  You do not need to uninstall the current version to upgrade.  Which version are you trying to move to?  The latest version on the 6.2 train is 6.2.1599.6, you can simply download the file csc6.2.1599.6.pkg file and upgrade through the GUI.  I would recommend performing a configuration backup prior to the upgrade, this can be done within the GUI under Admin>Configuration Backup.
Hope that helps!
Allen P Chen Wed, 09/29/2010 - 13:43
  • Cisco Employee,
I apologize, I just reread your post and realized that you are running software version 6.1.1569.2 (not 6.2.1599.2).  6.1 is pretty old, so you will need to go through incremental upgrades to move up to a later version.  Here are the files you will need:
csc6.1.1587.0.pkg
csc6.2.1599.0.pkg
csc6.2.1599.6.pkg
This will move you up to the latest version on the 6.2 train.
There is no way to upgrade the module through the CLI; however, you can re-image the module through the CLI.  The reason you might want to re-image is because you can just re-image it to a later version instead of performing incremental upgrades.  However, the downside to re-imaging is that you will lose all of your CSC configuration, so you will need to set it back up once it's been re-imaged.  You can also restore from configuration backup after it's been re-imaged as well.
Thanks!
