FXO - Stats - Uc500
Is there any way to have a graph or other nice stats to figure out the FXO utilisation.
I think that I have too much FXO line for my needs and I would like to gather more information...
I have a Uc500
5 Replies 5
Hi Philippe,
I tried to do this one time using SNMP and almost had it.
Unlike ISDN, we do not have a useful active calls mib to graph - unless I completely missed it!
The closest I could get was the voip call active table mib:
1.3.6.1.4.1.9.9.63.1.3.2
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=cvVoIPCallActiveTable
This lists all the active call legs - rather than a nice integer of the number of calls!
So my task was to create a script that determines the number of calls from this table.  Needless to say I had better things to do and forgot all about it.
I hope my past failure offers you some guidance!
Regards, Ash.
I have try to type this OID on PRTG or on a simple software as MIB-browser and it did'nt find anything on the UC500.
Doest someone can find the state of a FXO on a uc500 with a specific OID ?
thanks
Hi Philippe,
I have hunted around for this again and found a more promising oid:
1.3.6.1.4.1.9.9.62.1.3.2
I have tested this on a 2801 with vic2-4fxo and it displays the on-hook status.
Check whether this works for your UC500!
Regards, Ash.
The closest OID'S that i have is this :
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.19] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.20] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.21] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.22] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.23] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.24] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.25] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.26] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.27] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.1.28] = 1
[1.3.6.1.4.1.9.9.62.1.3.2.1.2.19] = 2
[1.3.6.1.4.1.9.9.62.1.3.2.1.2.20] = 2
[1.3.6.1.4.1.9.9.62.1.3.2.1.2.21] = 2
[1.3.6.1.4.1.9.9.62.1.3.2.1.2.22] = 2
[1.3.6.1.4.1.9.9.62.1.3.2.1.2.23] = 2
this is it ! when I call , those that have a value of one goes to 2
