CUCIMOC interaction with CAPF server
Sep 29th, 2010
I have cucimoc 8.0.2 registered with cucm 8.0.3 using tcp and udp. Now I want to try TLS. For this, I guess I need to make the cucimoc client interact with CAPF server to get the LSC (local significant certificate). Normally the cisco phones connect to CAPF server after the registration when the appropriate CAPF settings are configured for the phone. But the cucimoc is not initiating any attempt to contact CAPF server when I make similar configuration changes.
Did anyone encounter similar issue and has any solution to overcome it?
Thanks.
htluo Mon, 10/04/2010 - 11:58
CUCIMOC (a.k.a. CSF) uses certificates in its local store (which is the JRE certificate store).
Importing certificates into JRE certificate store is not very intuitive.  You may take a look at CUCIMOC docs or open a TAC case.
Michael
http://htluo.blogspot.com
