switchport port-security aging static command
Answered Question
Sep 29th, 2010
hi,
Can someone please explain we the above command with example.
many thanks
mahesh
Correct Answer by Jon Marshall about 6 years 5 months ago
mahesh18 wrote:
Hi Reza,
thanks for reply i read from cisco website following note but i did not understand what this mean
You can use port security aging to set the aging time for all secure addresses on a port.
Use this feature to remove and add PCs on a secure port without manually deleting the existing secure MAC addresses while still limiting the number of secure addresses on a port.
if you can explain me this please
mahesh
Mahesh
If you have a port security setting of 5 secure addresses allowed then when the switch has learnt these 5 addresses no more addresses will be allowed. If there is no aging time for the entries then the entry simply remains there as long as the switch is up. If you now want to remove one of the PC's and replace it with another you have a problem because the pot has already learned 5 addresses so it will not allow another.
This is where you use the aging timer. If for example you set the port-security aging timer to 1 then you would only have to wait one minute before the mac-address for the PC you disconnected is removed and now the switch only has 4 addresses learnt on that port. So you can now add your new PC and it will be allowed on that port and becomes the 5th address learned.
Jon
Overall Rating: 5 (1 ratings)
mahesh18 Thu, 09/30/2010 - 07:28
Hi Reza,
mahesh
Correct Answer
Jon Marshall Thu, 09/30/2010 - 09:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
mahesh18 wrote:
Hi Reza,
mahesh
Mahesh
Jon
mahesh18 Thu, 09/30/2010 - 09:36
Hi Jon,
Many thanks for wonderful explanation.
best regards
mahesh
