Date issue on SPA504G
Sep 29th, 2010
Today I discovered that it seems the phone in my office(SPA504G) doesn't believe that the 30th of September exists. I noticed this morning that the date had not changed from the 29th even though the time was all correct. So then I thought i'd try to update it manually but it simply would not accept the 30 as part of the date. I could quite happily change it to the 1st of October and back to the 29th of September but not the 30th. I tried a full factory reset and also two different firmware versions but still no go.
My phone is just a stand alone unit that I use with an external VOIP provider and I am using the web interface to configure it. I also tried upating the date directly from the phone but that didn't help either. Has anyone seen this before?
Matt
Brandon Svec Thu, 09/30/2010 - 14:21
Strange.  Are you using NTP?  I also have a SPA504G that I use on a non-Cisco PBX and it says 9/30/2010 on it right now..
Hardware 1.0.0(0001) and software 7.4.4
Brandon
