CAMs does not work in a cluster
Answered Question
Sep 29th, 2010
Tell  me please, I have two Cams worked in a cluster on version 4.1.8, after  updating to version 4.8.0, interfaces, synchronization can not see each  other and the tab failover each CAM neighbor is not active (dead)
Sincerely, Alexander
Correct Answer by Faisal Sehbai about 6 years 7 months ago
Alexander,
Check your certificates. Install the same certificate/private key pair on both CAMs.
More details here:
https://supportforums.cisco.com/docs/DOC-12609
Also other certificate related documents are available here:
https://supportforums.cisco.com/community/netpro/security/others?view=documents
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Thu, 09/30/2010 - 10:21
  • Gold, 750 points or more
Alexander,
More details here:
HTH,
Faisal
JUAN HUICAB Thu, 09/30/2010 - 10:55
I could see two possibilities:
a) Certificates issues, as Failsal said
b) Check by using "vi" that the insterfaces that you use for heart beat still the same as 4.1.8
