Showing results forĀ
Search instead forĀ
Did you mean:Ā
VTY line config deletes itself
brunstadnett
Hi!
I have a problem on  my AIR-AP1121G accesspoints. Sometimes they cannon be access via telnet, it works fine after a reload. This happens not very often, but when it happens, I need to reload it manually.
I'm using a backup tool, for backing up the running configs. Last report I got from an unavailable AP was that the line config for both console and VTY was missing. I think this is the case on the other APs as well. But why the backup could be done I don't know, the backup rutine is done via telnet.
Using this software: Cisco IOS Software, C1100 Software (C1100-K9W7-M), Version 12.3(8)JEC1, RELEASE SOFTWARE (fc4)
By the way I've read this thread but I'm already using the exec timeout option on all of the lines.
Serge Yasmine
I never heard of this on JEC1, can you share the script that you run to do the backup. Remember to remove usernames, password, ip addresses and so on before posting.
Thank you
Serge
Hi Serge!
I'm not using a script to do the backup, I'm using Kiwi Cattools. It's configured from a GUI.
Hello, ah ok, could be something is being pushed by Kiwi Cat Tools through another Job, check the Jobs and what is being configured on it. Normally, the configuration on the AP do not dissapear on their own.
Have a good day.
Serge
