Port VLAN assignment.
Sep 30th, 2010
I wondered how is possible to have a port "unassigned".
For example, suppose fa0/1 belongs to VLAN 10.
If I delete VLAN 10, is fa0/1 unassigned?
Or, as in running-config there is, under fa0/1, switchport access vlan 10, I have to command no switchport access vlan 10 too.
Thanks.
glen.grant Thu, 09/30/2010 - 05:46
  • Purple, 4500 points or more
   You cannot have a port as unassigned.  The default is vlan 1 for a port  if you set the port back to factory defaults .
Jon Marshall Thu, 09/30/2010 - 09:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Just to add to Glen's post. After you remove the "switchport access vlan 10" from the port run the command "sh vlan brief" on the switch. This will show you the vlans on the switch and which ports are allocated into which vlan. You should then see, as Glen said, that port allocated to vlan 1.
Jon
speculor_cisco Thu, 09/30/2010 - 11:06
I was reading the argument VMPS from the 2960 Software Configuration Guide, when I saw
the term "unassigned" about a port. So I asked for this term.
But now I have understood that the concept is relative to this configuration command:
switchport access vlan dynamic
When I configure a port with this command, the port should be "unassigned", before the
assignment done by the server.
Is it correct?
Jon Marshall Sat, 10/02/2010 - 08:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Is it correct?
Yes, in the context of VMPS an unassigned port has not be placed into a vlan yet.
Jon
yembasheerahamed Tue, 10/05/2010 - 22:03
        The interface status is default ie Vlan 1.  In globel mode apply ‘default interface fastEthernet 0/1’ . Then the interface set to default configuration.
For example :
Router#sh run int f 4/10
Building configuration...
Current configuration : 122 bytes
interface FastEthernet4/10
switchport
switchport mode access
no ip address
shutdown
end
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#default interface fastEthernet 4/10
Interface FastEthernet4/10 set to default configuration
Router(config)#end
Current configuration : 59 bytes
no ip address
shutdown
end
Router#
MB.Ahamed
Dan-Ciprian Cicioiu Tue, 10/05/2010 - 22:36
  • Gold, 750 points or more
Hello ,
i think that you are looking at a "show ip interface brief", and you see an unassigned , but that is the IP address that is unassigned
Dan
