Spanning Tree, Aggregated Ethernet, or Fail-Over on 6500
Sep 30th, 2010
My office is connected via Bridgeway 1Gbps microwave to another location, which becomes unusable during heavy rain/snow. The backup connection is a 25 meg Tsunami link that is able to better handle the interference. What do you think would be the best method of providing seemless redundancy between the two on a 6500 switch?
Thanks in advance,
Eric
You could either do this @ layer 2 and or 3.
What I would consider is using a method that uses either a keepalive or response test to make sure the link is there.  The other issue you have is stability - you don't want the link flapping all the time, so you can either use interface/route dampning.  With layer 2 you need to be mindful of port state transistions on span-tree unless you use 802.1w
What routing protocols do you run if any?  What span-tree are you currently using?
HTH>
