bad ACE module again... RDRAM
Answered Question
Sep 30th, 2010
customer's new ACE module can't boot. It is rebooting and the reason is:
<cut>
RDRAM Walking 1 Memory test failed channel 0 Device 0 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 1 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 2 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 3 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 4 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 5 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 6 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 7 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 8 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 9 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 10 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 11 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 12 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 13 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 14 IXP:2
RDRAM Walking 1 Memory test failed channel 0 Device 15 IXP:2
</cut>
I sent it back to Cisco. This is third ACE module with some HW problem (previous had problem with SRAM).
I'd like ask you, if these types of problems are 'normal' or only I have a luck for it :).
martin
Correct Answer by Ivan Kovacevic about 6 years 6 months ago
Hi Martin,
This is not very common. You are just very unlucky...
Ivan
Overall Rating: 5 (1 ratings)
Correct Answer
Ivan Kovacevic Thu, 09/30/2010 - 09:10
  • Cisco Employee,
Hi Martin,
Ivan
Ivan Kovacevic Thu, 09/30/2010 - 10:51
  • Cisco Employee,
If this happens again, please raise the issue with your partner or local Cisco Account Team
