MQC Qos on Sup6-E (Cat4500), Change DSCP to tx-queue mapping?!
Answered Question
Sep 30th, 2010
With MQC is it possible to change the default DSCP to tx-queue mapping ?
if yes, how ?
With Sup6-E the command "qos maps dscp <xxx> to tx-queue <y>" does NOT exist.
thanks for the help.
Ps: which is the default tx-queue to dscp mapping with sup6-E ? Same as Sup V ?
Correct Answer by Jason Masker about 6 years 5 months ago
The 6E uses MCQ based QoS. It supports up to 8 queues instead of the 4 queues supported by previous supervisors.  You identify the queues by creating a policy-map and applying it as an output service policy to a port.  See the configuration guide here:
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst4500/12.2/44sg/configuration/guide/qos.html#wp1531008
If you do not have a CCO you will need the PDF link. See the section specific to the 6-E.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/44sg/configuration/guide/qos.pdf
Overall Rating: 5 (1 ratings)
Correct Answer
Jason Masker Thu, 09/30/2010 - 08:25
Related Content
