Converting LAP back to autonomous failed
Sep 30th, 2010
I've a 1130 AP which doesn't boot it's LWAPP image from flash. So I tried to convert it back (with tftp server and so on) but after the message that it's using the "reset IP" it tries again to start the (corrupt?) image.
Is there a way to stop this boot cycles and to check boot parameter? Or any other ideas?
Madhuri C Sun, 10/03/2010 - 22:43
  • Cisco Employee,
To stop the reload of LWAP and to verify boot variable, you could issue:
AP#
debug lwap client no-rel
show boot
dir flash:
As stated in the above document, you could then convert using archive command method.
Madhuri
FRANK SCHADE Tue, 10/05/2010 - 23:39
thanks for all your hints - but I cann't even access the console. The boot process stucks here:
button pressed for 2 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...############################################################################################################################################################################################################################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
executing...
Than  nothing happens anymore (the same in non-reset-mode)
Is there something else wrong?
Madhuri C Wed, 10/06/2010 - 00:04
  • Cisco Employee,
What I see here is, it is loading the LWAP recovery image c1140-rcvk9w8-mx which has 'k9w8'
Have you verified that autonomous image is loaded to AP's flash ? If 'dir flash:' output has autonomous image which will have 'k9w7' then you could issue
AP#
debug lwap con cli
conf t
boot system flash:/
Madhuri
FRANK SCHADE Wed, 10/06/2010 - 00:21
as I said - the boot processs stucks at this state and I can't access to the console anyway.
regards
frank
vinodjad1234 Wed, 10/06/2010 - 00:44
If you are not able to convert through the procedure which i provided . Then please issue below command to get Image copied in Flash:
First boot your ap from tftp directly.
bring ap in rommon mode with the help of reset button.
you will get below mode
ap:
then give below command to boot from tftp directly.
ap : boot tftp:/ ..ip address .. / filename..
it will boot from tftp directly and after word you can copy .tar Image from with the help of below command
ap: archieve / download-sw / tftp:ip address... / file name ...
but make sure that you have enough space in your flash...
I reckon, it should work . let me know if you have any further issue ..
FRANK SCHADE Wed, 10/06/2010 - 23:18
there seems to be no change to stop the boot process.
Also with the the "tftp-procedure" it immediately starts to boot from flash and then stucks.
So I need a trick to interrupt the boot process.
thanks
praveenneti Wed, 10/13/2010 - 04:30
Hi Guys,
Today, I have converted the Cisco LWAP (1140) to Autonomous AP successfully.
Follow the below steps:
1. Download your 1142 image from Cisco --- I chose c1140-k9w7-tar.124-21a.JY.tar (Autonomous IOS Image for LWAP 1142)
2. Copy your 1142 image to your TFTP folder and start your TFTP server
3. Hook up your console cable and open up PuTTY
4. Plug in your 1142 into your POE/non-PoE (use Power Chord) switch.
5. Create one DHCP Pool in 10.0.0.0/24 network and let the LWAP and Laptop takes the IP from that DHCP Pool.
6. When it boots and your DHCP server gives it an IP address, you'll get a prompt (*your AP needs to get to your TFTP server)
Use PuTTY and enter in the commands in bold and modify the address of your TFTP server and image accordingly.
APd0d0.fdae.aea4> enable
Password: Cisco
APd0d0.fdae.aea4#debug lwapp client no-rel    ###### Very Important command
LWAPP ignore internal reload debugging is on
APd0d0.fdae.aea4
#debug capwap console cli   ######## After giving the above one, this particular command will activate.
CAPWAP console CLI allow/disallow debugging is on
APd0d0.fdae.aea4# archive download-sw /overwrite /force-reload tftp://10.0.0.10/c1140-k9w7-tar.124-21a.JY.tar    ######## After giving the above command "debug capwap console cli" then the "ARCHIVE" command will activate
It starts upgrading the new IOS to the LWAP. After installing the IOS, reboot twice the AP and you can normally see the prompt “ap>”
Praveen Neti.
