09-30-2010 07:32 AM - edited 03-16-2019 01:05 AM
We would like to know if it is possible to reject incoming calls with unknow calling number. It is possible to reject incoming calls with known calling number, it is possible to reject it in the gateway, but is it possibel with an unknow calling number?
Esteban
Solved! Go to Solution.
09-30-2010 07:50 AM
As long as it isn't coming in from an MGCP circuit, you can block the call with a call-block translation pattern which matches a null ANI.
Check out this link:
If you are running MGCP, I can't think of a way to do it, since CUCM can't match based on an ANI.
09-30-2010 07:34 AM
Are you using H.323 or MGCP ?
Note: it is common experience, that many calls without a calling number are perfectly legitimate.
09-30-2010 08:34 AM
Hi Paolo,
I confim you that is a H323 gateway.
The incoming calls could incoming for 4 different gateways, and for these gateways are incoming calls of different offices, then we will need to make a filter of incoming unknow calling number and known called number, is that possible.
Thanks for all,
Esteban
09-30-2010 08:36 AM
See the link given by Steven for how do that.
09-30-2010 07:50 AM
09-30-2010 11:38 AM
In the US it is common to ask the service provider to do this.
An advantage of this method is that the caller that is blocked gets a message instructing them to unblock their caller ID if they want to get through.
This is normally done wiht *82 prefix before the dialed number.
Brandon
