It is possible to have load balancing between 2 servers on a single switch?
Answered Question
Sep 30th, 2010
My question is: I will have packets that come from sw1 to a server, its possible to make load balancing on the switch in order to he decided if the packet goes to server 1 or server 2?
I cannot see how can be possible if the servers will have differents ip address.
Can anyone explain please?
Thanks in advance,
Tiago
Correct Answer by Jason Masker about 6 years 8 months ago
Here is the configuration guide for server load balancing, if your switch supports it.
http://www.cisco.com/en/US/customer/docs/ios/12_2/ip/configuration/guide/1cfsflb.html
If you do not have a CCO, use this link:
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfsflb.pdf
Correct Answer by Collin Clark about 6 years 8 months ago
You have two options; Server Load Balancing (SLB) on the higher end switches or the Application Control Engine (ACE).
Hope it helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Collin Clark Thu, 09/30/2010 - 07:49
  • Purple, 4500 points or more
Hope it helps.
Tiago Reis Thu, 09/30/2010 - 08:25
Wooohhh that was very fast .)
Thats something new for me. (always learning...)
Thanks for your help (both of you).
Best Regards,
Tiago
Related Content
