how to see object group counters
Sep 30th, 2010
show ip access-list
permit object-group web_ports object-group vlan1 any (18013384 matches)
shows the total counts for all web ports
show object-group web_ports
object-group service web_ports
tcp eq www
tcp eq 443
tcp eq 8080
tcp eq 8443
tcp eq 4443
how can i see the counts for each tcp ports within the object group?
Panos Kampanakis Thu, 09/30/2010 - 13:46
Unfortunately on IOS you can only see the aggregate counters of an ACE with an object-group. You can't seen the hitcounts of the expanded ACL.
I hope it is clear.
