Help with Port range forwarding
Sep 30th, 2010
Switching from RV082 router to SA520 K9 router. In the RV082 router under the setup tab, and then forwarding. I have a udp and tcp service running on port 7195, to our server address 192.168.xx.x. I can not find where I would be able to do the same thing on the SA 520 K9. This is so when people go to our webpage and click on a link it brings up a webpage that connects to our database. The only thing I found was where can setup a service, but it does not point to our server address, which makes it where it does not work.
Thank you for any help that gets our web access for our patrons running again.
