What kind of certificate I can use?
Sep 30th, 2010
Currently I´m trying to create a certificate for to use in WSA. I have the options I attached.
Does anyone could tell me which type of certificate should be created for upload to the WSA?
Thanks and regards,
Jaime.
edadios Tue, 10/05/2010 - 20:34
  • Silver, 250 points or more
Hello Jaime,
The WSA uses Root Certificate only.
Please see thiskb article http://tinyurl.com/67ejzo
So the screen you are on, in Microsoft CA is not the certificate you use  on the WSA.
You use the CA Cert, which is the root certificate.
I hope this clarifies it for you.
Eric
