ether-channel configurations
Sep 30th, 2010
There is a command in IOS XR - "bundle minimum-active links 2"  that will take the bundle-ether interface down if the an interface goes down.  There is NOT an equivalent command in standard IOS.  Does anyone have a solution/workaround to drop a port-channel if one of the physical interfaces goes down?
Tom Prevost Thu, 09/30/2010 - 10:18
correction - if one of the physical interfaces goes down.....
Mahesh Gohil Fri, 10/01/2010 - 01:55
  • Silver, 250 points or more
Hi thomas,
I am using below command
int port-channel 1
channel-group minimum active 2
but it depend upon platform and IOS whether it is supported or not
hope this help
mahesh
