DNA shows Block this Pattern but users can make calls
Sep 30th, 2010
In trying to find the call flow on CUCM 6.1, the DNA kept showing Block this Pattern for all DNs in all Calling Search Spaces.  Yet, the users were able to make calls.  I have seen this in other instances as well.  The DNA shows Block this Pattern when the users are, in fact, able to make calls.  Is this a bug with the DNA?  Is there a way to get it to work so I don't have to manually trace the call flow?  Thanks.
Overall Rating: 4 (2 ratings)
Lakshmi Adapala Fri, 10/01/2010 - 08:48
  • Cisco Employee,
Basically the CSS of the calling device should be able to reach the partition of the called device/route pattern etc. So basically on the DNA are you selecting the CSS of the calling and entering the called digits exactly as they are dialed from the calling ?
d.anthony.hadley_2 Fri, 10/01/2010 - 09:00
Yes, correct.  I choose, in the drop down box, the calling search space of the DN making the call, then the time zone, called number. And it always says Block this Pattern.  Yet, the user can dial the number with no problem.  So, I'm getting a false reading from the DNA, or something.
Lakshmi Adapala Fri, 10/01/2010 - 09:02
  • Cisco Employee,
What is the result in the DNA if you try with out selecting time zone (just calling, called numbers and CSS) ?
Lakshmi
d.anthony.hadley_2 Fri, 10/01/2010 - 09:31
When I leave the default time zone in there, it is still blocked.  I treid several time zones and several calling search spaces and numerous DNs and telephone numbers, with the 9, with 91, with out any prefix.  They are all the same.
kusatija Fri, 10/01/2010 - 09:36
  • Silver, 250 points or more
Also,
the DNA may or may not show how things actually are working in the backend, ideally if you have any call routing issues, always go for a call manager trace.
Now tell us the calling called party numbers, and upload the routeplan report with ccm traces from all nodes.
If the issue is just to clarify the behaviour, it could be that there are more Potential matches for the call and the call manager in the backends goes to the next match if one is blocked or has a partial match, but i think the DNA is just showing the first match and not the potential matches, and thats why the calls are not failing even the DNA shows it is hitting the Block this pattern.
Please recheck your route plan report
Cheers!
Kunal
Rob Huffman Fri, 10/01/2010 - 09:41
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Anthony,
Could be this bug;
CSCsw69333 Bug Details Bug #9 of 14 | < Previous | Next >
DNA does not take into account Allow Overlap Sending configuration
Symptom
DNA shows Block This Pattern when overlap sending is enabled
Conditions
Add route pattern of 0.00 with Allow Overlap Sending checkbox selected.
In DNA enter 0000 and it will return Block this pattern.
Work Around: None
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
6.1
7.0(2)
Fixed-In Fixed-in
6.1(3.9901.102)
8.0(0.38000.280)
7.1(1.39000.126)
7.0(1.21022.1)
7.0(2.11004.1)
6.1(3.9999.1)
7.1(2.10000.16)
6.1(4.1000.10)
8.0(1.10000.40)
Cheers!
Rob
d.anthony.hadley_2 Fri, 10/01/2010 - 10:41
Yes, I just wanted to clarify the behavior because I've seen it several times now on several different CUCMs. I was wondering if it was something that I was doing or there is some peculiarity to the behavior.  I'll go for the traces, which is what I've done before.  Thanks for the responses.
Related Content
