H-REAP Vlan Confusion
Sep 30th, 2010
I'm getting ready to setup one of our remote sites with wireless access of data only, no voice or customer access.  Looks like H-REAP is the solution.  Attached is a diagram of one of our remote site's connectivity and actual vlans.
The following details may be helpful to know:
All LAN vlan routing is static with all vlans advertied out on BGP
Workstations DHCP with a local site server
Phones DHCP with one of the local switches
Currently running a 5500 series WLC at Corporate
Plan to use the 1142n or new 3500 APs
Max 3 APs per site
Remote sites run an ISR and 3560G switches
So, how would I configure routing and switching for the AP's data and control?
mlc
Nicolas Darchis Thu, 10/07/2010 - 22:56
  • Cisco Employee,
Hi Mic,
You need to configure the switchport where APs are conencted as trunk.
The native vlan of the trunk will be the capwap vlan. So pick a "management" vlan where clients don't have access.
Then assign to the AP (from WLC) a vlan for the data SSID. You can pick the same vlan as the workstations.
As simple as that ...
