Difference between FTE-10G and SFP-10G-SR
Sep 30th, 2010
Hello
I would appreciate the help for explain me the difference between FTE-10G and SFP-10G-SR, being focus on an architecture Nexus.
Thanks in advanced.
Alexis Munoz
Overall Rating: 5 (1 ratings)
Jerry Ye Thu, 09/30/2010 - 19:22
  • Cisco Employee,
The FET-10G is only supported between the Nexus
Supported for fabric links only (Cisco Nexus 2000 Series to Cisco parent switch)
Cisco Fabric Extender Transceiver must be connected to another Cisco Fabric Extender Transceiver
Supported on Cisco Nexus 2224TP, 2248TP, and 2232PP uplinks
Supported on Cisco Nexus 5000 and Nexus 7000 Series Switch fabric links
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps10110/data_sheet_c78-507093.html
While the SFP-10G-SR can be used to connect between the Nexus to other Cisco or 3rd party products, like Nexus to Catalyst 6500.
HTH,
jerry
g.fabre Fri, 08/24/2012 - 02:53
I have a question related with this : can we connect FEX to Nexus 5000 with other transceivers than FET (SFP-10G-SR for instance) ?
would Nexus accept other vendors SFP+ (AP783A HP for instance) ?
thanks in advance !
dsolangon Fri, 08/24/2012 - 04:07
Hi for nexus hp have a propaitary sfp exclusive for hp only. The only sfp that is compatible in Cisco is allied television sfp sx for iOS. I haven't tried it to nexus or XR
Jerry Ye Fri, 08/24/2012 - 05:10
  • Cisco Employee,
Nexus and FEX will accept SFP-10G-SR.
For 3rd party tranceiver, I know it works (I have a customer using some 3rd party twinax cables right now).
HTH,
jerry
g.fabre Fri, 08/24/2012 - 05:55
thanks for your answers !
I found there is a command to make "unsupported sfp" working, but I prefer running compatible ones for sure
