Migrating from ASA5505 7.2 to ASA5510 8.3
We have ASA5505 running 7.2 and will be replacing the unit with ASA5510 shipped with 8.3 - better performance.
Do we save the running config in the current asdm 5.2 and then import the config somehow in asdm 6.2?
Or is it easier to cut and paste into the CLI from old to new?
There is no migration guide using asdm posted on Cisco site......
Scott Nishimura Thu, 09/30/2010 - 13:36
Hi Timothy,
I understand that you will be upgrading and migrating to a new ASA device.  The easiest way to upgrade the ASA would be to first go to 8.2 code on your 5505.  Then upgrade your 5505 to 8.3 code which will upgrade your configuration to 8.3.  You can then copy and paste but you will have to also make sure that you adjust the interfaces and other things which are different between 5505 vs. 5510.     Also, We  only recommend and support going from 8.2 to 8.3 due to the number of massive changes to the configuration.   I'll include a netpro doc link which has a lot of good information.  Upon loading up of the new 8.3 code, the configuration will be auto migrated.  I'll include a migration doc that you will need to read and understand as there are alot of changes to the code.
Its advisable to do this through the cli by following one of the docs available online.  Be sure also that your 5510 has the memory upgrade which is required for 8.3.
8.3 upgrade info:
https://supportforums.cisco.com/docs/DOC-12690
8.3 migration info:
http://www.cisco.com/en/US/docs/security/asa/asa83/upgrading/migrating.html
8.3 release notes with instructions to upgrade:
http://www.cisco.com/en/US/docs/security/asa/asa83/release/notes/asarn83.html#wp452287
thanks,
scott
mirober2 Thu, 09/30/2010 - 13:37
EDIT: Scott beat me to it...please disregard
Hi Timothy,
ASA 8.3 requires ASDM 6.3, so you would have to follow a process like this:
1. Upgrade the 5510 to 8.2
2. Load ASDM 6.3 on the 5510
3. Import the 5505 config into the 5510
4. Upgrade the 5510 to 8.3
Hope that helps.
-Mike
Message was edited by: mirober2
Related Content
