CUCX 5 CUCM 7 compatiblitiy?
Answered Question
Sep 30th, 2010
I cannot find anything to tell if they are compatible.
Also, this is for the IE Lab.  I only have acess to CUCX 5.0.  How much does it differ from CUCX 7?  Wondering if I will be able to improvise for my studies.
Correct Answer by Jason Hutchinson about 6 years 3 months ago
Whereas they are differnt in some capacity, they are very similar.
Here is a compatibility matrix so you can also chek the compatibility of you UCCX application with the CUCM application.
6.x - 8.x Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
3.x - 5.x Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crsmatrxeol.pdf
Jason M. Hutchinson
Overall Rating: 5 (1 ratings)
Correct Answer
Jason Hutchinson Fri, 10/01/2010 - 11:01
6.x - 8.x Matrix
3.x - 5.x Matrix
Jason M. Hutchinson
