Cisco Clean Access Update Website and Firewall Port Required
Answered Question
Sep 30th, 2010
I was wondering if anyone may know the website the clean access manager would be using to upate as well as the firewall port required. This is due to a firewall in place. Based on some reading, not sure if it uses other website besides the following http://www.perfigo.com/clean_machine_1/version-se.txt on port 80.
Thanks.
Correct Answer by Faisal Sehbai about 6 years 8 months ago
For CAM checks and rules update, that's the only site required.
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Fri, 10/01/2010 - 07:52
  • Gold, 750 points or more
HTH,
Faisal
