Cisco LMS 3.2 with DFM 3.2 cannot handel 3560V2
Sep 30th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Hello Support Community,
we have a problem with Cisco Works LMS 3.2 and DFM 3.2.
DFM 3.2 cannot handel Cisco WS-C3560V2-24PS Switches.
First of all some facts.
Server Hardware
IBM system x 3560m2
   - 2x 146GB SAS Harddisk (Raid 1)
   - 6 GB Memory (Windows only support 4GB)
   - Intel Xeon CPU 2.40 GHz
LMS is installed on Windows 2003 Standard R2 32bit English  fully updated via Microsoft Online Update.
LMS updated via Common Services>Software Center online from Cisco.com.
Typ of Switchs
WS-C3560V2-24PS
Version 12.2 (53) SE2
Image C3560-IPBASEK9-m
ObjectID 1.3.6.1.4.1.9.1.1021
LMS and DFM both Version 3.2
Device Packages installed in DFM.
   - DFMDeviceUpdates 12.0
   - DFMSharedUpdates  2.0
The Device Typ Count under Common Services>Software Center>Device Update list the WS-C3560V2-24PS Switch Type.
Now our Problem. When we Import the Devices in DFM all WS-3560V2-24PS Switches after the discovery, we will have status UNKOWN.
In all other moduls like RME, HUM and so on we have no problem to handle WS-C3560V2-24PS Switches.
We have tried to delete and re-add that device in DFM without any result.
Thank you in advance.
Joe Clarke Fri, 10/01/2010 - 20:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is a new DFM device update available (13.0) that provides 3560V2 support.  I just confirmed your sysObjectID is supported.
