Can't connect to N type wireless WRT120N
Answered Question
Oct 1st, 2010
Hey guys!
I have a vaio EB2S1E and one router Linksys WRT120N. Both devices have the N wireless standard. When i set the router to Wireless N-only, my notebook cannot conect to it anymore, i see it as a device but after i  enter the SSID and password it will not connect. If i leave it to Mixed or Wireless G-only or set it to Wi-Fi Protected Setup the notebook connects fine and i am amble to copy with 2.5 mb/sec
I have posted a picture with the settings, can anyone tell me what am i doing wrong?
[URL=http://img196.imageshack.us/i/capturehv.jpg/][IMG]http://img196.imageshack.us/img196/7143/capturehv.jpg[/IMG][/URL]
PS I have two onboard LAN cards on my PC one Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller and one Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller. Is there any difference between them, besides the name? Which one is better to use with my router?
Thank you for reading this!
Correct Answer by Calin Chiorean about 6 years 5 months ago
Sorry Paul I have experience with Cisco not Sony-Vaio, but I believe you can set this somewhere in your OS settings.
Calin
Overall Rating: 5 (2 ratings)
Calin Chiorean Fri, 10/01/2010 - 02:04
  • Silver, 250 points or more
Hello Paul,
I see on your pictures that you set Linksys on N-only. Can you do the same on Vaio? Use only N on both sides and try.
Then you said "i  enter the SSID and password it will not connect" what is the error message on your Vaio?
Regarding your Ethernet card, I see that one is PCI and the other one PCI-E (PCI Express). Different slot type.
Calin
paulie.link Fri, 10/01/2010 - 02:54
Hey Calin,
I do not know how to set my vaio to connect only to N networks, can you tell me how to?
The error message is the same as if i were typing the SSID password wrong, which i ain't cause i checked multiple times
Both of my LAN cards are onboard, they do not use any PCI or PCI-E slots...
Correct Answer
Calin Chiorean Fri, 10/01/2010 - 03:02
Calin
paulie.link Fri, 10/01/2010 - 03:06
Hey, i see that you have a romanian name, are you romanian? If you are could i contact you through email or some im adress? Thank you, have a nice day!
paulie.link Fri, 10/01/2010 - 03:58
Ok, i have played with the settings and put specially AES encryption type and now my vaio connects fine to the N standard, i now copy with 7.5 mbs. Solved!
Calin Chiorean Fri, 10/01/2010 - 04:00
Great! Thanks for sharing your solution!
P.S. I've added you as a friend on this community
Calin
