SRP 572 drops ADSL connection overnight
martin.dye
I have recently purchased 2 SRP 572 W for 2 clients.
Set them up using the wizard, just for ADSL no voice, and every morning they have to reboot the router to get their ADSL working.
Can anyone point me in what direction I should be looking?
The lines have been tested by telecoms compaines and are working fine with no faults.
Any advise would be appreciated.
Many Thanks
Martin
2 Accepted Solutions
Alberto Montilla
Dear Martin;
There is a known issue for certain configurations when not using the voice ports. Please disable the voice ports (go to voice section, then to Line 1 - Disable the line, do the same for Line 2 and submit changes and reboot. This should make the deal.
If this works for your configurations, please let me know
Alberto
Andrew Hickman
Hi Martin,
Just one other comment - If you wish to configure the full set of functionality of the SRP500, please log in with admin/admin.
Also, we a planning to release a firmware update soon - this also has a couple of fixes that will help with some ADSL training issues that a few people have seen.
Cheers
Andy
Alberto Montilla
Dear Martin;
Alberto
Many Thanks Alberto for the prompt reply.
At the moment (fingers crossed!) one of the routers is working, the second for some strange reason decided to lose it's configuration!
So I'll be re-installing it Tuesday week after sitting my Microsoft MCITP exams.
I'll let you know then, and after the weekend I'll confirm the state of play on router 1.
Many Thanks
Alll the Best
Martin
Hi Albetro,
Sorry it's a been a while since I started this blog and replied to your answer.
The router was faulty and exchanged!
The same problem occured so I set it up as you suggested and all is now ok.
Many Thanks for your input and Andy.
Andrew Hickman
Hi Martin,
Cheers
Andy
