LMS 2.5 & Cisco Catalyst 2960 Switches
Oct 1st, 2010
Hi Folks,
I have the following software and its updates(below). When I discover devices on my network it doesn't recognize cisco 2960 switches. When I want to upgrade the devices it says that all the updates are already installed. How can I solve this issue?? Any Ideas? How can I upgrade to RME 4.0.3?
Thanks in advance for your help.
Tito
Bundles Installed
Bundle NameVersionInstall Date
1.LMS2.501 Sep 2010
Products Installed
Showing 1-7 of 7 records
Product Name Version Installed Date
1.CiscoWorks Common Services3.0.223 Sep 2010, 16:47:42 VET
2.Campus Manager4.0.227 Sep 2010, 10:11:12 VET
3.CiscoView6.1.001 Sep 2010, 09:19:28 VET
4.Device Fault Manager2.0.001 Sep 2010, 10:53:49 VET
5.Internetwork Performance Monitor2.6.001 Sep 2010, 11:59:22 VET
6.Integration Utility1.6.001 Sep 2010, 09:19:34 VET
7.Resource Manager Essentials4.0.223 Sep 2010, 17:17:19 VET
Nael Mohammad Tue, 10/05/2010 - 00:35
Go to Common Services ---> Software Center ---> Software Update and select to download updates for all the applications. Then go to the download directory and install each update separate. The downloads should be in the psu_download directory such (/opt/psu_download/ or C:\psu_download\ where application name is rme, cmf, dfm, or cm).
SSDTTIS00 Thu, 04/07/2016 - 08:40
same problem several years later... Did you get the updates? Could you please send them to us?
Thanks ;-)
David
