Collect Digits Step Initial Timeout
Oct 1st, 2010
Is there a way to set the initial timeout in the Collect Digits step to a value less than 1? I have a script that invites callers to enter an extension number now, or hold for more options. A one second time out delay is too long but the step does not seem to accept anything less. Is there a syntax I should be following or is 1 the minimum value?
Bruce Wilkinson
Jason Hutchinson Fri, 10/01/2010 - 10:53
  • Cisco Employee,
You are stating that the 1 second timeout for entering digits is....  too long ????
valiegenus Sun, 10/03/2010 - 05:46
check VRU default list in ICM configuration manager--->interdigit value
ithink it's from 1-99
so 1 sec is the minimum.
