ehwic on cisco 2811
Answered Question
Oct 1st, 2010
Hello Expert,
Can ehwic be use on cisco 2811?
I know this can be use on cisco 2901 routers
Jomo
Correct Answer by krahmani323 about 6 years 5 months ago
Hello Jomo,
Not expert but I will try to answer :
1/ From this page  http://www.cisco.com/en/US/prod/collateral/modules/ps5949/qa_c67-612908.html
Q. Are there any restrictions or considerations I should be aware of?
A Yes, Following is a summary of a few limitations when using the EHWIC switch:
• The EHWIC switch is not supported on older ISR platforms (Cisco 1841 and Cisco 2800 and 3800 Series).
2/ http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/geSwitchEhwic_hw.pdf says :
Cheers!
Karim
Overall Rating: 5 (1 ratings)
Correct Answer
krahmani323 Fri, 10/01/2010 - 10:37
Hello Jomo,
Cheers!
Karim
